Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 07-08-2012, 06:08 PM   #1
Maytag Top Loader leaking
I took the front off to get a good look at inside. Bone dry. Why then do I have a small leak after each load of laundry?
JanetReiss is offline   Reply With Quote
Old 07-08-2012, 06:19 PM   #2
the Musigician
DangerMouse's Avatar
Perhaps a hose is not tight? Have you looked at the back? Where is the water?
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 07-08-2012, 06:35 PM   #3
I changed the hoses. One seemed to be rusted out at the threads. But still leaking. Seems to be from bottom. Small puddles of water after spin cycle.
Old 07-08-2012, 06:37 PM   #4
the Musigician
Did you replace the rubber washer(s) too? They are necessary for a tight seal between hose and washer.
DM
Old 07-08-2012, 09:38 PM   #5
Yes. Hoses are dry. Inside machine is dry. Never looked underneath though.
Frigidaire Front Loader leaking jniter Appliances 1 01-16-2012 09:12 AM
Maytag Refridgerator water leaking bingo22 Appliances 2 12-05-2011 09:35 AM
Maytag Leaking LITTLECHEF12 Appliances 0 11-14-2011 03:06 PM
Maytag washer is leaking during spin cycle AngieP Appliances 6 05-27-2011 01:40 PM
MayTag Neptune washer leaking door Ufers5 Appliances 4 12-06-2010 02:01 PM
