-   -   Maytag Top Loader leaking (http://www.diychatroom.com/f47/maytag-top-loader-leaking-149599/)
JanetReiss 07-08-2012 06:08 PM
I took the front off to get a good look at inside. Bone dry. Why then do I have a small leak after each load of laundry?
DangerMouse 07-08-2012 06:19 PM
Perhaps a hose is not tight? Have you looked at the back? Where is the water?
DM
JanetReiss 07-08-2012 06:35 PM
I changed the hoses. One seemed to be rusted out at the threads. But still leaking. Seems to be from bottom. Small puddles of water after spin cycle.
DangerMouse 07-08-2012 06:37 PM
Did you replace the rubber washer(s) too? They are necessary for a tight seal between hose and washer.
DM
JanetReiss 07-08-2012 09:38 PM
Yes. Hoses are dry. Inside machine is dry. Never looked underneath though.
