Maytag Side By Side - Appliances - DIY Chatroom Home Improvement Forum
Old 02-13-2011, 06:50 PM   #1
RCDD
Maytag Side by side
Hey guys, just a quick question for everybody. My side by side is making a load humming noise and then a click. It does this about every 5-10 minutes. The freezer is not getting cold anymore and the fridge side seems to be warming up. Would you guys have any suggestions.
dannykapp is offline   Reply With Quote
Old 02-13-2011, 07:00 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
if you know nothing about refrigerator compressors, you will need to call a repairman. You either have a bad compressor relay (good ) or a bad compressor (bad).
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 02-13-2011, 07:19 PM   #3
RCDD
Hopefully it is something easy, the fridge is only about 4 years old. Good thing the one out in the garage is working, had to move everything. And would you know it we just got back from grocery shopping.
Old 02-13-2011, 08:57 PM   #4
Rewards Points: 530
Aren't these things warranted for several years. If so, it may be getting toward the end, and I would be checking real quick in case it is the comprssor and not the relay.
Hardwareman, do you know how long the closed system is warranted?
Old 02-13-2011, 10:09 PM   #5
#1 HAWKEYE FAN
Maytag like all manufacturers switched to a 1 year warranty about 5 years ago. Sucks, but it is just that
The Following User Says Thank You to hardwareman For This Useful Post:
boman47k (02-14-2011)
Old 02-14-2011, 08:30 AM   #6
Rewards Points: 530
After I posted that, I read somewhere something about most only being warranted for a year now. A few high end models may be exceptions, I didn't know.
I remember reading somewhere many years ago an article about the best buys in the market for consumers. Appliances were near the top as they could be expected to last many years, 15 to 20 rings a bell. Not so by a long shot now. Seems more like 5 to 7 if your lucky.
I once got a truck load or two of used appliances that had been removed by the store that sold them ( Lowe's, I think). Seems like it was like 50 ranges and some fridges. There were some very old units, some classics that would have brought good money from a restorer. Not much wrong with some of them if anything. Some were just old. Might have still outlasted the ones that replaced them.
I agree, it sucks. Seems so many things now are geared toward a throw away society.
I don't think the Maytag repairman is so lonely anymore. The ones that do not get that reference are younger than I am.
Old 02-15-2011, 05:40 AM   #7
The appl manf have changed their warranties; citing it was an added expense and not high on consumers list of important things-who they kiddin'!! with the new E mandates, price sensitive shoppers, and the round robin of dissatified customers with non-performing/crappy appliances they knew it was going to be a nightmare keeping up with warranty calls....there is no escape at any price point..lower end gets sent to landfill-high end gets big repair bill or crappy service if they have a contract..
Jacques is offline   Reply With Quote
Old 02-15-2011, 07:24 AM   #8
RCDD
I unplugged it over night, plugged it back in in the morning and it seemed to start cooling again. Then last night I heard the hum and click again and it quit cooling again. I called the local repair guy and he told me to try the start/relay and capacitor attached to the compressor. I ordered both online this morning, so hopefully that is all it is. I really do not want to have to replace the compressor on a 4 year old fridge.
Old 02-15-2011, 05:22 PM   #9
#1 HAWKEYE FAN
look at the name plate on the compressor, if its a Tecumseh your probably wasting your money on the relay, if its a Danfoss you'll probably be ok will the relay.
Old 02-16-2011, 07:53 PM   #10
RCDD
Well, installed the relay and no luck. Same problem as before. I talked to the repair man again and he said to check the owners manual and see if the compressor is covered under warranty. According to the manual the compressor is covered up to 5 years. I am going to try and call Maytag in the morning and see what they say. The only problem is I do not have the receipt to prove the original purchase date. Hopefully this will not give them an excuse to do any warranty work.
Old 02-16-2011, 08:31 PM   #11
#1 HAWKEYE FAN
watch out, no receipt could mean trouble. Where was it purchased, maybe they have some type of record.
Old 02-16-2011, 08:48 PM   #12
RCDD
I am not sure where it was purchased or when exactly. The house is 4 years old and we are the second owner, so all I have is the owners manual. I might be able to find out from the previous owner.
Is changing the compressor hard to do? Not that I am going to even try to attempt.
Old 02-16-2011, 10:52 PM   #13
#1 HAWKEYE FAN
changing the compressor would be the most technically involved repair on your refrig, normally costs would run about $350.00 to $450.00. With no purchase receipt they will go by the serial# to verify manufactured date, if it is 1 day over 5 you will be SOL
Old 02-17-2011, 07:39 AM   #14
You didn't post you're model serial # but there was a free recall on the relay/ol on some units..was it fried?? if you're on the list they may change the comp if you're pesty enough..
Old 02-17-2011, 07:55 AM   #15
Rewards Points: 530
Check out www.repair.maytag.com for info on some recalls.
They reference 23 reports of relays overheating and causing fire and smoke damage.
Actually, I think it says 23 "additional" reports. May or may not be related to yours, but it does give a contact link to check with someone.
Whirlpool Side By Side Not Making Ice Anymore!! handy man88 Appliances 57 07-14-2011 06:33 AM
GE side by side JohnJak Appliances 1 09-29-2009 08:41 PM
Kenmore side by side refrigerator not cooling bidderbl Appliances 1 09-26-2009 06:48 PM
GE Side by side water dispenser not working cfinchapex Appliances 3 09-19-2009 10:39 AM
Very Small leak at Shower Valve on Cold Water Side, Threaded. Tighten it more or ? twilightcall Plumbing 3 08-25-2008 08:19 AM
