Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 04-28-2008, 02:11 PM   #1
Question
Maytag refrigerator problem
I am new here and posted it in the wrong place. Reposting to the (hopefully) correct forum.
Hello,
I have a 7 year old Maytag side by side refrigerator which sits in the garage. Couple of days ago it stopped cooling. I unplugged it and plugged it back again. I find that I hear a relay click, the lights dim and the relay clicks back again a few seconds later (the lights turn bright again). This happens every half a minute or so. I can hear the fan but the compressor is not starting. Any help will be appreciated. Thanks.
gachar001 is offline   Reply With Quote
Old 04-28-2008, 03:18 PM   #2
jeff1's Avatar
Hi,
Ooops.
Yup
Model#?
Low voltage ( extension cord ), bad compressor, bad start relay/overload would be suspects.
If compressor, check your warranty in your use and care manual.
Some helps...
http://www.applianceaid.com/refrigerator.html#clicking
jeff.
Appliance Repair Aid
JRAppliance
jeff1 is offline   Reply With Quote
Old 04-28-2008, 06:09 PM   #3
Question
The Model # is MSD2454FR
I opened the back of the refrigerator and checked a few things.
1. The fan works, the relay clicks (loudly. It was not this loud before)
2. I can hear the compressor running. Then the relay clicks after a couple of seconds and the compressor stops.
3. I followed the instructions on the website link you sent me.
4. The capacitor seems ok.
5. I was not able to test the compressor amperage since I was not able to get my multi meter leads into the contacts.
6. I removed the white box (which clicks. I am assuming this is the relay). The box has 3 wires connected to it (orange, white and blue) on one side. On the other side, it is connected to the 3 pins on the compressor.
7. This box is rattling and some black crystal like substance is pouring from it. It looks like the culprit.
Where can I get a replacement part? Also where can I find the part number?
It has the following things written on it .
On the outer side
4SP1034
17 B00R
On the inner side
762PFBYY
-53 APX9A
Thanks for your help.
Old 04-29-2008, 12:47 AM   #4
jeff1's Avatar
MSD2454FR
Missing a digit.
MSD2454FRQ MSD2454FRW
Amp meter is clamp on around the wire...
http://www.applianceaid.com/electric...ting_tips.html
New replacement relay kit...
Relay/overload assy - part number 12002783
jeff.
JRAppliance
Old 04-29-2008, 01:19 PM   #5
Just ordered it. Will update you after I install the part.
Old 04-29-2008, 02:07 PM   #6
jeff1's Avatar
Please do
jeff.
Old 05-07-2008, 02:34 PM   #7
Thumbs up
Thanks Jeff.
I received the parts, installed it and it works fine. There was a black cap which goes over the overload and relay. It was hard to put on so I just left it off.
Old 05-07-2008, 05:01 PM   #8
jeff1's Avatar
?Cap? as in capacitor?....or the cover?
jeff.
JRAppliance
Old 04-21-2010, 06:22 PM   #9
Hey guys
i'm new here and new with diy stuff. could someone please help me with following.
My bad part is this:
i ordered a new overload and relay kit and received this:
will i be able to replace the old part with this new one? i mean it is still sealed in the bag and i was about to returned when i stumbled across this web page. if not will someone please post a webpage where i could buy the old school part.
btw. i got a maytag MSD2454FRW.
thanks everyone and sorry for my english.
zmaj is offline   Reply With Quote
Maytag range enamel problems?? ctnative Appliances 3 06-07-2008 02:42 AM
Maytag refrigerator problem gachar001 General Discussion 1 05-01-2008 05:38 PM
Maytag Dryer Squeel DIYLI Appliances 1 03-30-2008 02:43 PM
