Maytag Refrigerator Not Cooling - Appliances - DIY Chatroom Home Improvement Forum
Old 10-01-2009, 07:46 PM   #1
Maytag refrigerator not cooling
my 2001 maytag wide by side model mzd2766ge is freezing but not cooling. The temperature remains at 40 degrees even when the setting is changed to coolest or warmest. Can you offer some suggestions as to what the problem might be?
lucek is offline   Reply With Quote
Old 10-02-2009, 02:31 AM   #2
GetYourShineBox's Avatar
seems like a defrost problem. take the back panel of the freezer off and see if the evaporator coil has heavy ice build up. if it does, then its likely its the defrost heater not doing its job but it could also be the defrost timer or the defrost theromstat. if the evaporator coil has no build up then its likely its the air diffuser/damper control. which is located between the freezer and refrigerator compartments. if there is ice build up on the evaporator, test out the defrost system(you would need a multimeter). to test out the components of the defrost system...
Locate the pin in the center of the defrost timer and using a standard screwdriver, turn it clockwise until it clicks. Wait a few minutes and check if the defrost heater warms up.
If the defrost heater warms up, then its the defrost timer.
If it doesnt warm up,unplug the fridge and check the defrost heater for continuity(ohms).
If the defrost heater has no continuity(infinity ohms), replace it.
If the defrost heater is closed(an ohm reading), then replace the defrost thermostat.
GetYourShineBox is offline   Reply With Quote
Maytag range LP back to NG jdoff Appliances 9 10-23-2013 12:59 PM
Help! Just changed my Fan Controler (ICM 275) now system "false starts" when cooling redmachodevil HVAC 4 01-26-2011 03:21 AM
kenmore 596.58695890 cooling issues mindraven Appliances 7 08-22-2009 08:00 AM
My air conditioning (cooling) has gone away guptaalok HVAC 4 05-20-2009 12:43 PM
