Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 03-08-2011, 08:36 PM   #1
maytag refrig. mod msd2456geq ice maker leak
This refrigerator is ten years old and has always had a service warranty which recently expired.Since it was new it has only had a few minor issues but the ice maker has always been problematic. Under warranty the whole unit has been changed three times.The refrigerator is a side by side with freezer on the left. The fan in the freezer is mounted on the back wall above the coils with no pan under it. The problem is that the coils keep freezing up and there is about an inch of ice in the bottom of the freezer and water periodicly leaks out onthe kitchen floor. I know I have a water leak but can never find it. I dont know how to find it or what to do next. Any help would be appreciated.
alwaysomething is offline   Reply With Quote
Old 03-08-2011, 09:25 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
it is not a water leak, what you have is a plugged defrost drain tube. You need to remove the back panel of your freezer, at the bottom just below the coils you will see a drain trough. take a hair dryer and melt all that ice until you have a drain tube that flows freely. You may have to try and force a wire down that tube to unblock it.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 03-13-2011, 04:22 PM   #3
hardwareman:
Thankyou for the advice on how to fix my "water leak." Like you said the drain was frozen and appeared to have a blockage which was cleared with a heat gun, a piece of wire and a good flushing with about 5 or 6 large glasses of boiling water.Thanks again.
Joe
Old 03-13-2011, 04:34 PM   #4
#1 HAWKEYE FAN
no prob, glad to help
Maytag MBF2256KEQ Refrigerator Leak FYI StahlMaster Appliances 0 03-07-2011 12:19 PM
carrier weather maker 9200 leak craiglalonde HVAC 5 12-12-2010 11:39 PM
Kenmore (Whirlpool) refrig ice maker problem lexort Appliances 16 07-01-2010 03:00 PM
Water Leak in Maytag LA511,,, jjjoooggg Appliances 1 04-10-2010 11:32 AM
Ice Maker Plastic line leak socalsurf Plumbing 3 11-08-2009 05:35 PM
