Maytag Refridgerator Water Leaking - Appliances - DIY Chatroom Home Improvement Forum
Old 12-04-2011, 08:42 PM   #1
Maytag Refridgerator water leaking
Maytag model MSD2454FRW leaks inside freezer at bottom and is coming out of a grill area that has a type of steel reservoir behind it. What is cause?
bingo22 is offline   Reply With Quote
Old 12-04-2011, 08:45 PM   #2
Rewards Points: 13,446
Drain line is plugged up.
Differant brand, but this will give you an idea of where to look. If you do a key word search on you model you may find more info.
http://www.paulstravelpictures.com/H...tor/index.html
bingo22 (12-04-2011)
Old 12-05-2011, 08:35 AM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
yeah drain tube is plugged. Take the cover off the evaporator and you will see ice built up in the drain trough. Melt the ice with hair dryer or hot water(messy) continue to melt until the drain tube is running water. This will take a while.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Maytag Leaking LITTLECHEF12 Appliances 0 11-14-2011 02:06 PM
Maytag washer is leaking during spin cycle AngieP Appliances 6 05-27-2011 12:40 PM
MayTag Neptune washer leaking door Ufers5 Appliances 4 12-06-2010 01:01 PM
leaking roof couchguy Roofing/Siding 1 02-13-2010 04:43 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 08:53 PM
