-   -   Maytag Refridgerator water leaking (http://www.diychatroom.com/f47/maytag-refridgerator-water-leaking-125625/)
bingo22 12-04-2011 08:42 PM
Maytag model MSD2454FRW leaks inside freezer at bottom and is coming out of a grill area that has a type of steel reservoir behind it. What is cause?
joecaption 12-04-2011 08:45 PM
Drain line is plugged up.
Differant brand, but this will give you an idea of where to look. If you do a key word search on you model you may find more info.
http://www.paulstravelpictures.com/H...tor/index.html
hardwareman 12-05-2011 08:35 AM
yeah drain tube is plugged. Take the cover off the evaporator and you will see ice built up in the drain trough. Melt the ice with hair dryer or hot water(messy) continue to melt until the drain tube is running water. This will take a while.
