Maytag Refigerator Issue - Appliances - DIY Chatroom Home Improvement Forum
Old 01-03-2012, 12:57 AM   #1
I have a Maytage refigerator...I think it's about 5 years old. Freezer on top fridge on the bottom with a built in icemaker.
I've been having problems with water leaking out (seems to come from somehwere underneath the fridge) and the freezer wasn't properly defrosting. In doing some research online, I've already made sure the underside of the fridge is cleaned out (it was spotless) and the water supply for the icemaker is tight (it was).
Three months ago we also emptied the freezer and let it thaw out. This helped the defrosting issue, but there is a bit of frost in the freezer.
cpfoutz is offline   Reply With Quote
Old 01-03-2012, 09:01 AM   #2
sleepyg's Avatar
Rewards Points: 8
Sounds like the defrost only works some times. Make sure the defrost works as it should, if there is ice build up in a frost free fridge then you have a defrost issue.
sleepyg is offline   Reply With Quote
Old 01-03-2012, 11:33 AM   #3
Or the drain line is clogged and all of the defrost run-off is re-freezing.
jfrotten is offline   Reply With Quote
Old 01-04-2012, 08:39 AM   #4
sleepyg's Avatar
Rewards Points: 8
The OP said that he was getting water on the floor and inside the fridge, that is what I based MY reply on.
Maytag range LP back to NG jdoff Appliances 9 10-23-2013 01:59 PM
10+ Maytag washer oil leak. LAT2300AAE rebar Appliances 5 05-31-2011 03:18 PM
Maytag Washer repair tom wells Appliances 2 01-01-2011 08:58 AM
Maytag IntelliDry pye/4500 Dryer not working 57_Hemi Electrical 2 11-19-2010 10:28 PM
Maytag dishwasher upper sprayer arm agarwal450 Appliances 3 06-21-2008 10:49 PM
