#1 |
Maytag range LP back to NG
I have a Maytag MGR5755QDQ that I bought used. It had been converted to LP, and the original orifices were lost. I need to convert it back to NG.
The problem is that Maytag doesn't list part numbers or even show that the NG orifices are available separate from the assemblies that hold them (and there are six: four burners, oven, broiler), which would cost more than I paid for it. I've spoken to Maytag dealers and the factory parts service, and I'm currently waiting for a Maytag distributor to "email the manufacturer", but I'm not hopeful. So, what should I do? I figure I can drill out the existing orifices and make the other adjustments in the conversion manual, but I'm not sure what sizes are correct. The stove has (in NG mode) two 9.2K burners and two 12K burners, which I think corresponds to 1.50 mm and 1.70 mm, but I'm not positive. And I have no idea what the oven and broiler orifices sizes are or should be. |
#2 |
Okay, I think I'm getting somewhere.
First of all, the conversion manual does give me some information on the oven and broiler orifices. The LP oven orifice is marked ".049", which means that its size is 0.049 inches. The broiler orifice is marked "#57", which means that it's 0.043 inches, according to this chart: http://www.bacharach-training.com/orifice_chart.htm Now, that chart is even more useful because I can cross-check the burner orifices to see if I'm on the right track, as well as use it (with some assumptions) to figure out what size the oven and broiler orifices should be. Here's what the manual for the range says about the burners, which matches the chart fairly closely, if I assume that my NG regulator is set at 4.0 inches of water: Code:
orifice LP BTU LP size NG BTU NG size ------- ------ ------- ------ ------- F burn. 10,500 0.038 in 12,000 0.067 in R burn. 9,100 0.035 in 9,200 0.059 in Code:
orifice LP BTU LP size NG BTU NG size ------- ------ ------- ------ ------- oven 17,000* 0.049 in 20,000* 0.084 in* broiler 13,000* 0.043 in 15,000* 0.074 in* * estimated |
#3 |
Anyone know of a good appliance repair forum?
#4 |
Master General ReEngineer
Ayuh,...
In my experince,... There's what I guess would be called the stove's Master Orifice,.. I know you only need to change a Single Orifice to convert a stove from LP to NG... When I bought mine from Sears a few years ago,.. I set it up for the LP,+ taped the NG part to the back of the stove, down by where it gets Changed.... I would think any Maytag Dealer could sell you the part you Need,.... |
#5 | ||
Maytag range LP back to NGQuote:
#6 | |
#7 | |
Well, then you should do Maytag a favor and tell them all their manuals are wrong.
#8 |
I Apoligize,... I stand Corrected...
In the 35+ years of messing with the occasional gas ranges,... I've Never seen 1 so Involved, just to convert gases... |
| Display Modes | |
| Gas Range | cookiemom1970 | Plumbing | 1 | 11-14-2008 05:58 PM |
| back button not working | joed | Site Help and Suggestions | 9 | 11-12-2008 01:08 AM |
| New Range Wiring | c086473 | Electrical | 4 | 03-11-2008 09:50 PM |
| 3 prong range? | laduehelp | Electrical | 39 | 03-11-2008 02:33 PM |
