-   -   Maytag range LP back to NG (http://www.diychatroom.com/f47/maytag-range-lp-back-ng-36946/)
jdoff 01-27-2009 09:20 AM
I have a Maytag MGR5755QDQ that I bought used. It had been converted to LP, and the original orifices were lost. I need to convert it back to NG.
The problem is that Maytag doesn't list part numbers or even show that the NG orifices are available separate from the assemblies that hold them (and there are six: four burners, oven, broiler), which would cost more than I paid for it. I've spoken to Maytag dealers and the factory parts service, and I'm currently waiting for a Maytag distributor to "email the manufacturer", but I'm not hopeful.
So, what should I do? I figure I can drill out the existing orifices and make the other adjustments in the conversion manual, but I'm not sure what sizes are correct. The stove has (in NG mode) two 9.2K burners and two 12K burners, which I think corresponds to 1.50 mm and 1.70 mm, but I'm not positive. And I have no idea what the oven and broiler orifices sizes are or should be.
jdoff 01-27-2009 04:32 PM
Okay, I think I'm getting somewhere.
First of all, the conversion manual does give me some information on the oven and broiler orifices. The LP oven orifice is marked ".049", which means that its size is 0.049 inches. The broiler orifice is marked "#57", which means that it's 0.043 inches, according to this chart:
http://www.bacharach-training.com/orifice_chart.htm
Now, that chart is even more useful because I can cross-check the burner orifices to see if I'm on the right track, as well as use it (with some assumptions) to figure out what size the oven and broiler orifices should be.
Here's what the manual for the range says about the burners, which matches the chart fairly closely, if I assume that my NG regulator is set at 4.0 inches of water:
Code:
orifice    LP BTU    LP size    NG BTU    NG size
F burn.    10,500    0.038 in  12,000    0.067 in
R burn.    9,100    0.035 in    9,200    0.059 in
Using the LP/NG size ratios of the burner orifices, and the size/BTU information from that chart, here's my best guess as to the correct NG orifice sizes for the oven and broiler:
Code:
oven      17,000*  0.049 in  20,000*  0.084 in*
broiler    13,000*  0.043 in  15,000*  0.074 in*
* estimated
I'd prefer to know the exact correct sizes for the oven and broiler orifices, but if I can't find that, does my method seem reasonable? Does the heat output in BTUs seem correct for the oven and broiler, or am I way off?
jdoff 01-29-2009 09:19 PM
Anyone know of a good appliance repair forum?
Bondo 01-30-2009 12:30 PM
Ayuh,...
In my experince,...
There's what I guess would be called the stove's Master Orifice,..
I know you only need to change a Single Orifice to convert a stove from LP to NG...
When I bought mine from Sears a few years ago,..
I set it up for the LP,+ taped the NG part to the back of the stove, down by where it gets Changed....
I would think any Maytag Dealer could sell you the part you Need,....
jdoff 01-30-2009 12:43 PM
Originally Posted by Bondo (Post 221934)
Ayuh,...
In my experince,...
You're probably thinking of the regulator. All that does is regulate the gas pressure differently for LP and NG (something like 11 and 4 inches of water, respectively). You still need to replace orifices for each burner, the bake orifice, and the broil orifice, as well as adjust the air shutters and possibly burner valves.
So would I. That's not the case. See the OP.
Bondo 01-30-2009 12:45 PM
Nope,..... You're Wrong.....
jdoff 01-30-2009 01:04 PM
Well, then you should do Maytag a favor and tell them all their manuals are wrong.
Originally Posted by Maytag Installation Manual, page 7
To convert the unit to either LP or Natural gas will require adjustment of the air shutter on the bake & broil burner, adjustment of the pressure regulator converter cap, and replacement of the bake and broil burner orifice hoods and top burner orifices.
Here's a link if you don't believe me: Installation Manual for Gas 30-inch Wide Free-Standing Range
Bondo 01-30-2009 02:09 PM
I Apoligize,... I stand Corrected...
In the 35+ years of messing with the occasional gas ranges,...
I've Never seen 1 so Involved, just to convert gases...
rich in mi 10-23-2013 12:53 PM
HELP I have the same issue
JEFF, DID YOU EVER FIGURE THIS OUT?I HAVE THE SAME ISSUE AND NEED TO DETERMINE THE DRILL SIZES TO DRILL OUT THE OVEN AND BOILER ORIFICE FROM LP SIZES TO NATURAL GAS SIZES ON A MYATAG MGRS752BDW GS RANGE. I HAVE ALREADY BOUGHT THE TOP BURNERS IN NAT. BUT THE OVEN AND BOILER I AM SURE NEED TO BE CHANGED TO A LARGER SIZE? HELP HELP HELP RICH IN MI:furious:
rich in mi 10-23-2013 12:59 PM
I sure hope someone knows?
MAYTAG MGRS752BDW NEED TO CONVERT BACK TO NATURAL GAS FROM LP. WHO CAN TELL ME WHAT THE DRILL SIZES ARE TO DRILL OUT THE OVEN AND BROILER ORIFICE (SPUDS) TO THE NATURAL GAS SIZES? MAYTAG DOES NOT LIST THE PART AND SO FAR I HAVE HAD NOTHING BUT DEAD ENDS TRYING TO GET HELP.
RICH IN MI
son.follower1 at gmail.com
