Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 10-02-2012, 08:43 AM   #1
Maytag Performa Stove not maintaining baking temp
I have a gas stove a Maytag Performa barely past the 5 year warranty on electrical parts (naturally), and the baking temperature inside the stove does not maintain the temperature setting, if I set the temp to 400 degrees via the electrical setting switch, it will reach that temperature and then begin to decrease down to about 200 degrees and not rise again, so I switch from bake to broil and once the broiler flame ignites, which usually takes awhile, I switch back to bake and only then will the temperature maintain the desired 400 degrees once reached and stay there, i'm not sure if this is a problem with the elctrical switch or possibly grease in the jets, i tried using the self clean feature several times to clean out grease possibly from the jets but that didnt solve the problem, i have not spilled grease inside nor is the stove at all dirty, the stove uses the same compartment for baking and broiling, the broiling flame from above and the baking flame from underneath the pan beneath the grill, any thoughts on how to fix this myself?
sweets is offline   Reply With Quote
Old 10-02-2012, 06:21 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
my best quess would be you have a weak ignitor. You'll have to watch the ignitor when the oven is dropping in temp to see if it is glowing.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 10-03-2012, 04:00 PM   #3
I was told once ovens need tune ups every year or so to make the temperature stay consistent.
bdwilliams is offline   Reply With Quote
Old 10-03-2012, 08:32 PM   #4
#1 HAWKEYE FAN
not true
Peerless oil furnace - keeps turning on when temp exceeds target temp eugenet1979 HVAC 0 12-22-2011 09:30 PM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 09:55 AM
Do you have a Wood/Pellet Stove Insert with a Raised GRANITE Hearth? gmoom Remodeling 1 01-24-2011 05:54 PM
converting maytag stove to nat gas tiger76 Appliances 0 01-31-2010 02:46 PM
Best High Temp Paint for wood stove?? Sellncars Painting 9 01-21-2009 07:21 PM
