Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 12-03-2010, 09:26 PM   #1
Maytag LA511 squeal
Maytag LA511 top loading washing machine sqeals during spin cycle and sounds unbalanced. Is this due to bellts & bearings or something else? Works OK otherwise and only occurs during high speed spin.
blumagnet is offline   Reply With Quote
Old 12-03-2010, 10:44 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Maytag LA511 squeal
probably belt slipping. this washer has 2 belts 1 for the pump and 1 for the drive. replace both at the same time. very easy to change, tip it back about 6 inches the belts are on the bottom of the washer, no tools requireed.
hardwareman is offline   Reply With Quote
Old 12-04-2010, 02:58 AM   #3
Maytag LA511 squeal
Thanks for the info. I"ll give it a try and let you know.
Old 12-04-2010, 11:38 AM   #4
Maytag LA511 squeal
this was a great washer. built for 30 yr' service..if the belts don't fix it call a local guy and have it repaired [brg's are going]. it's a pricey repair but there's nothing on the market today that's comparable.
Jacques is offline   Reply With Quote
Maytag IntelliDry pye/4500 Dryer not working 57_Hemi Electrical 2 11-19-2010 10:28 PM
Water Leak in Maytag LA511,,, jjjoooggg Appliances 1 04-10-2010 11:32 AM
Maytag LA511 Toploading banging.... jjjoooggg Appliances 5 03-31-2010 08:52 AM
Maytag range LP back to NG jdoff Appliances 7 01-30-2009 03:09 PM
Maytag dishwasher upper sprayer arm agarwal450 Appliances 3 06-21-2008 10:49 PM
