Maytag Gas Dryer - Heats Only Sometimes - Appliances - DIY Chatroom Home Improvement Forum
Old 06-10-2014, 03:36 PM   #1
Rewards Points: 37
Maytag Gas Dryer - Heats only sometimes
Maytag model SDG4506AWW...about 10 years old.
Sometimes it heats. Sometimes it doesn't. I took off the front panel and the ignitor glows red. Sometimes I see a flame, other times I don't. I checked under the filter and cleaned in there a little, but I didn't see anything big stopping the air flow.
This all started after I put a large load in the dryer (bigger than I should have and ran the dryer. Hours later, it was still running with no heat and wet clothes. Then, then next day, it seems to heat up and work fine. Today (a few days later) it seems to be sporadically heating again. I just took the front off and did a test run. I saw the ignitor glow and saw a flame and it was producing heat. I let it run for about 5 minutes (no clothes inside) and then I opened it and it wasn't hot.
What should I test? Thanks!
ed3120 is offline   Reply With Quote
Old 06-10-2014, 06:55 PM   #2
Rewards Points: 14,278
http://www.repairclinic.com/RepairHe...roubleshooting
Old 06-10-2014, 10:15 PM   #3
Rewards Points: 342
The model numbers listed don't match yours (4506). Could it be 4000, 405D, or 4606, by chance?
jmon is offline   Reply With Quote
Old 06-10-2014, 10:21 PM   #4
Rewards Points: 342
First verify your model number.
Most common problems are thermal fuse or gas valve solenoid. Click on link below, then click on part testing/replacing video for thermo fuse and gas valve solenoid and see if they are at fault. Could be something else, but start there.
dryer not heating
Old 06-16-2014, 07:38 PM   #5
Rewards Points: 37
It was the solenoids. I changed them out and it works now. Easy install. Thanks.
The Following User Says Thank You to ed3120 For This Useful Post:
jmon (06-16-2014)
Old 06-16-2014, 07:49 PM   #6
Rewards Points: 342
Your welcome. Great. Glad everything worked out for you. Thanks for the update. This post may help someone else having the same problem. Thanks.
Another Dryer Question 3 to 4 wire John3rd Electrical 15 07-29-2015 01:10 PM
Maytag Dryer problem Master Brian Appliances 16 07-26-2014 12:00 AM
[Help] changing a Maytag dryer from a 4 prong cord to a 3 prong cord noonance Electrical 8 02-26-2013 07:12 PM
Maytag IntelliDry pye/4500 Dryer not working 57_Hemi Electrical 2 11-19-2010 09:28 PM
Maytag gas dryer problem Rick V Appliances 2 02-08-2009 01:48 PM
