Maytag Fridge - Push Water Button Ice Comes Out - Appliances - DIY Chatroom Home Improvement Forum
Old 11-19-2013, 06:41 PM   #1
Woody10's Avatar
Rewards Points: 29
My Maytag fridge has three buttons - water, crush and ice. We used it for water an hour ago and now when water is selected and the button pushed ice comes out.
Any ideas? Is the button just not selecting water? Not sure what to do.
Thanks!
Woody10 is offline   Reply With Quote
Old 11-19-2013, 07:04 PM   #2
Rewards Points: 142
If water pressure and filter are good it may be the water inlet valve. Strange all of a sudden it stop working. If nothing is functioning at all with dispenser, may be the dispenser control board (not likely).
Try unplugging fridge for awhile then plug it back in, see if that helps. Sort of a reboot.
How old is fridge?
jmon is offline   Reply With Quote
Old 11-19-2013, 07:20 PM   #3
Woody10's Avatar
Rewards Points: 29
I just emptied the ice out to check if it's making ice correctly.
The odd thing is when I push the water button you hear the ice dispense turn on and if there was ice in the tray the ice will drop out.
It's like the button has changed to ice.
Old 11-19-2013, 07:49 PM   #4
Rewards Points: 142
Unplug fridge from power for awhile, then plug back it back in again. See if that helps. Thanks.
The Following User Says Thank You to jmon For This Useful Post:
Woody10 (11-20-2013)
Old 11-19-2013, 07:52 PM   #5
Rewards Points: 142
What is the model number of your maytag fridge?
Old 11-20-2013, 08:14 PM   #6
Woody10's Avatar
Rewards Points: 29
Just wanted to say thanks. Unplugged it for awhile last night and when I woke up this morning it was working again. Maybe something froze up and thawed itself. Thanks again.
Old 11-20-2013, 08:15 PM   #7
Rewards Points: 142
Your welcome. Glad everything worked out for you.
Warm Water out of Cold Water Outlet mb0709 Plumbing 9 08-26-2012 01:59 PM
Toilet flush issue. Paradiselost Plumbing 7 06-19-2012 01:47 AM
Softened water to fridge ice maker? droopdog7 Plumbing 0 05-29-2011 04:58 PM
Water line to fridge, actually -in- 'subflooring', not under?? Anonyone Plumbing 5 10-16-2010 07:31 PM
water borehole question joeuser General DIY Discussions 2 04-18-2010 11:33 PM
