Maytag Fridge MTB2156geb Evaporator Fan Wiring Problem - Appliances - DIY Chatroom Home Improvement Forum
Old 03-11-2011, 01:34 PM   #1
Maytag Fridge MTB2156geb evaporator fan wiring problem
I am replacing the evaporator fan in the freezer. The original motor ( panasonic udqrc02mgl ) has 2 wires blue and white. The replacement (panasonic udqr002mb ) has a 4 wire female connector. I do not have a pigtail for this. What should be the proper terminal placement for the wires ?
Dennit1 is offline   Reply With Quote
Old 03-11-2011, 08:21 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,586
return it, its the wrong motor
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is online now   Reply With Quote
Old 03-14-2011, 03:43 PM   #3
I have the same issue. The original fan was changed by a repairman in the past (under warranty). I believe he put the wrong motor on and cut the original wiring harness off to make the "new" one work. I'm now trying to put the correct fan back on (UDQR002MB) but am not sure how to wire it because the plug from the wiring harness is now incorrect. Can you tell me which terminals the blue and orange wires should attach to?
westsideguy is offline   Reply With Quote
Old 03-14-2011, 04:33 PM   #4
#1 HAWKEYE FAN
post model# and part# you are trying to put on
Old 03-15-2011, 10:46 AM   #5
Actually, I got it figured out. It looks like I was looking at the wrong fan in the first place. Thanks to your info, I located the correct part number for my fridge and installed it last night. Unfortunately, it is the Panasonic (#UDQR002MB), so I'm anticipating another failure in the future.
Dryer on the fritz.. wiring problem? cisco10 Electrical 17 11-19-2009 02:26 PM
diagnose house wiring problem brhodewalt Electrical 7 05-06-2009 10:03 PM
trailer wiring problem dns Automotive Repairs 2 10-09-2007 03:50 PM
My ceiling fan wiring problem jkrodger Electrical 9 08-13-2007 04:51 PM
Thermostat Wiring Problem crazy woman HVAC 2 08-15-2006 10:22 AM
