Maytag Dryer Question - Appliances - DIY Chatroom Home Improvement Forum
Old 01-19-2010, 09:43 AM   #1
Question
Maytag Dryer Model# 86880100 Heat is fine in timed mode,but very little heat when using preset modes.(Perm. Press,regular,etc)
Mr.Pappy is offline   Reply With Quote
Old 01-21-2010, 06:22 PM   #2
Rewards Points: 530
I'm thing you have a different thermostat that works the timer in that situation. Interesting. I may have to do some looking around to find the answer.
One thing to check might the selector switch.
Old 01-24-2010, 07:19 AM   #3
humidity sensor
The driers I have worked on have a mushroom shaped humidity sensor wired inline wit the element which controls the heat element on auto cycles.
If in a manual setting the drier is fine, then the element itself and timer are likely OK. If the humidity sensor fails the drier either runs on and on with no heat or shuts down early leaving a damp load.
Also try running the drier with the vent pipe disconnected from the wall in case there is a clog causing humidity to back up into the drier , however this is not likely if it works Ok on timed cycles.
Chemist1961 is offline   Reply With Quote
Old 01-29-2010, 11:16 PM   #4
Rewards Points: 530
humidity sensor
Dryer vent backdraft damper BlueCrystalMan Building & Construction 4 01-01-2010 02:26 PM
gas dryer connection question rvegab00 Plumbing 7 12-07-2009 10:53 AM
dryer question cawlady Electrical 4 11-19-2009 07:23 PM
Help, how & where can I vent a 2nd floor dryer? jaes Remodeling 2 06-28-2008 10:03 AM
Dryer Vent Question jlaky2000 HVAC 2 03-13-2008 08:22 PM
