-   -   Maytag Dryer Question (http://www.diychatroom.com/f47/maytag-dryer-question-62270/)
Mr.Pappy 01-19-2010 10:43 AM
Maytag Dryer Model# 86880100 Heat is fine in timed mode,but very little heat when using preset modes.(Perm. Press,regular,etc)
boman47k 01-21-2010 07:22 PM
I'm thing you have a different thermostat that works the timer in that situation. Interesting. I may have to do some looking around to find the answer.
One thing to check might the selector switch.
Chemist1961 01-24-2010 08:19 AM
humidity sensor
The driers I have worked on have a mushroom shaped humidity sensor wired inline wit the element which controls the heat element on auto cycles.
If in a manual setting the drier is fine, then the element itself and timer are likely OK. If the humidity sensor fails the drier either runs on and on with no heat or shuts down early leaving a damp load.
Also try running the drier with the vent pipe disconnected from the wall in case there is a clog causing humidity to back up into the drier , however this is not likely if it works Ok on timed cycles.:thumbsup:
boman47k 01-30-2010 12:16 AM
humidity sensor
:thumbsup:
