Maytag Dryer Drum Won't Start When Hot - Appliances - DIY Chatroom Home Improvement Forum
Old 01-10-2011, 02:33 PM   #1
Maytag dryer drum won't start when hot
I have a Performa Maytag Dryer Model # PYG2000AWW. When the unit is cold, it will start and run fine. After the first load is done and the dryer is still hot, I put a new load in from the washer and all I get is a load buzz but the drum won't spin. I can start the drum manually and then quickly shut the door and it will work.
I have already replaced the belt as the unit is over 10 years old. Could it be the solenoid or the motor? How can I test to see what might be the problem?
Thanks!
dmdonnay is offline   Reply With Quote
Old 01-10-2011, 02:49 PM   #2
Experienced
Jackofall1's Avatar
Definately the motor, the buzz is the sound a motor makes when it has what is called a "Locked Rotor".
Old 01-10-2011, 10:00 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
yup. motor .
hardwareman is offline   Reply With Quote
frigidaire dryer has excessive vibration gmoliver Appliances 17 09-10-2015 11:13 PM
Electric Dryer not turning on c.abrams Electrical 3 01-09-2011 07:18 PM
Dryer exhaust duct not connected inside dryer frankrizzo Appliances 4 02-09-2010 09:47 PM
Dryer vent. kcrossley2 Plumbing 10 02-20-2008 01:02 AM
lights brighten or dim at motor start geeyathink Electrical 4 07-07-2006 10:06 PM
