Maytag Clothes Washer - Appliances - DIY Chatroom Home Improvement Forum
Old 08-12-2011, 11:01 PM   #1
How do you remove stuck corrugated drain hose on model MAV9557593EA from stand pipe?
preagan is offline   Reply With Quote
Old 08-13-2011, 03:06 PM   #2
Rewards Points: 161
I would use some liquid detergent or spray silicone down the stand pipe. Let it sit for a while. If you still can't pull it out then take a piece of stiff copper wire, bend small "L" on the end and slide down beside the hose and hook it on the edge of the hose to assist pulling it out. It worked for me. Good luck.
kb3ca is offline   Reply With Quote
Old 08-13-2011, 03:33 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
What's the standpipe made of?
XXX
Old 08-13-2011, 04:36 PM   #4
If you have hard water, it could be a calcium build-up. Soak it down with lime-away
Master of Cold is offline   Reply With Quote
Old 08-14-2011, 09:25 PM   #5
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
on the end of some of those plastic corrugated hoses Maytag used a rubber snubber type thing on the end to hold it in the drain. Hang onto the stand pipe and pull the hose out.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 08-15-2011, 05:44 PM   #6
Your not using the right cuss words..
Air injector broken -- Maytag topload washer TryHard Plumbing 18 07-17-2015 07:47 PM
maytag top load washer not spinning at times ed lee Electrical 2 01-07-2011 12:37 PM
MayTag Neptune washer leaking door Ufers5 Appliances 4 12-06-2010 01:01 PM
washer and Clothes coming out of washer stink. rsplash40 Appliances 11 07-03-2009 11:05 AM
Maytag Washer and GFI mwarken Appliances 3 12-09-2008 03:22 PM
