Maytag Bravos Pump Breaks From Pocket Change-help! - Appliances - DIY Chatroom Home Improvement Forum
Old 10-11-2012, 05:49 PM   #1
Rewards Points: 91
Maytag Bravos pump breaks from pocket change-help!
I have a Maytag Bravos washing machine. Money keeps getting in the pump. Its driving me crazy. I don't know how it gets in there. Then the pump cracks and I fix it with epoxy. Now I need a new pump but it is, apparently, not available any more. What can I do to replace the pump and how is the money getting into the pump. I can not afford a new washer. I am desperate.
sofasurfer is offline   Reply With Quote
Old 10-11-2012, 07:17 PM   #2
Rewards Points: 13,270
#1 Check all pockets before doing wash.
If you just type the make model# on Google I'll bet there's at least 100 sites where you can buy that pump.
Have you contacted Maytag and asked?
Old 10-11-2012, 09:02 PM   #3
Rewards Points: 91
I did find it on Ebay.
My main question is, isn't there protection against change going into the pump? I don't understand how its getting in there.
Old 10-12-2012, 09:53 AM   #4
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
Bravo pumps are readily available, should not be an issue. If you leave things in your pockets they will end up in the pump. Like I tell all my customers, CLEAN YOUR POCKETS BEFORE EVERY LOAD. There is no type of filter or protection to elimate this problem.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 05:28 PM
Heat Pump blowing warm air after T-Stat change ericivins HVAC 5 03-04-2011 07:22 AM
Maytag washer bearing change Manicmech Appliances 3 10-07-2009 05:12 AM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
On a scale of 1 -10 how hard is it to change a sump pump? abefroman Plumbing 11 02-26-2009 11:20 PM
