Manual For Vitamaster - Appliances - DIY Chatroom Home Improvement Forum
Old 07-20-2010, 07:01 AM   #1
Rewards Points: 150
Manual for Vitamaster
i just realized the cat peed on "Wifey's" treadmill during the remodeling. now i must disassembled it for proper cleaning (a must w/ cat urine).
As i started to disassemble it i noticed how well it was put together. it is an older unit and i'd guess American made. it is at least 25 years old.
the casing is only marked with "VITAMASTER" AND "CUSHION." there is no indication of model.
would anyone know where i could get a manual for this treadmill?
Manual for Vitamaster-dscf3180.jpgManual for Vitamaster-dscf3181.jpgManual for Vitamaster-dscf3182.jpgManual for Vitamaster-dscf3184.jpgManual for Vitamaster-dscf3183.jpg
rosco is offline   Reply With Quote
Old 07-20-2010, 07:18 AM   #2
Rewards Points: 150
if you look at the last few pictures - i've removed the screws going horizontally. now, it seems i should remove the three bolts seen going vertically.
but looking at page 16 in this manual http://www.scribd.com/doc/5013163/Treadmill-Manual, that seems to be similar in design, that all the pieces might come apart and i won't be able to get it back together (ex: the fiber board servicing as a frame for the belt will come loose). if i take it apart, i must get it back together as it is a personal item "she" used with her mother (satan's sister).
by the way, i'm still hoping to find a manual of this unit or a similar one that would describe how to disassemble the unit (directions using pictures are best for me).
Manual for Tempstar furnace ? Where? cody21 HVAC 1 04-05-2010 12:04 PM
Manual transfer switch to power an existing sub-panel joestewart Electrical 10 11-23-2009 03:30 PM
Thermostat from Manual to Digital trinamillersmit HVAC 5 07-02-2009 10:21 AM
manual J question drewhart HVAC 2 01-31-2009 05:45 PM
needing manual HandyMac Landscaping & Lawn Care 2 07-03-2008 03:26 PM
