Manitowoc JY0205W Ice Machine - Appliances - DIY Chatroom Home Improvement Forum
Old 06-19-2012, 01:54 PM   #1
I have a problem with the water pump which is brand new not being
able to pump the water up to the distribution pipe which allows water to flow over the ice cube tray. I have tryed adjusting the water pressure, float, water level. I did notice on the computer board that
the water light is not on green. I also tried priming the water tube and that hasn't worked. What might the problem be?
Greg Ferensic is offline   Reply With Quote
Old 09-17-2013, 02:22 PM   #2
Pump
Try covering the hold on the bottom of the pump tray for a bit. If your pump turns on due to a water level issue then perhaps your pressure isn't high enough or I guess constricting the hold could work but I don't know how that might effect production.
dsloga is offline   Reply With Quote
Manitowoc Ice Machine problem TNSmith Appliances 10 03-26-2015 08:30 AM
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 04:30 AM
manitowoc ice machine nigel nish HVAC 2 01-15-2012 07:52 AM
Manitowoc Ice machine dollarman6 Appliances 2 08-08-2011 11:07 PM
manitowoc ice machine fts1966 HVAC 1 07-07-2011 05:04 PM
