Magic Chef Oven Fault Code F-5 - Appliances - DIY Chatroom Home Improvement Forum
Old 08-24-2011, 07:56 PM   #1
Magic Chef Oven fault code F-5
I have a Magic Chef electric stove model# 3868 XVA and when I try to use the oven or broiler, I get a F-5 fault code on the clock display. All the stove top elements are working fine but anything to do with the oven gets the fault code. Any suggestions would be deeply appreciated.
bigalp is offline   Reply With Quote
Old 08-24-2011, 09:51 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,586
you have a bad elctronic control board, replace
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 08-25-2011, 08:28 AM   #3
The electronic control board, is this the clock assembly or is it some other part? Someone said that the F-5 fault could be related to the door latch switch.
Old 08-25-2011, 08:56 AM   #4
#1 HAWKEYE FAN
clock assy
The Following User Says Thank You to hardwareman For This Useful Post:
bigalp (08-29-2011)
Carrier 9200 Code 34 fault cu1982 HVAC 8 01-02-2009 09:56 PM
Oven - junction box in cabinet DIYGST Electrical 5 11-13-2008 04:23 PM
NEC 2008 Code Cycle jamiedolan Electrical 19 10-05-2008 07:42 PM
Another Bryant 383KVA with code 31 problems rpgIVguru HVAC 1 02-05-2007 02:47 PM
1950's Roof Framing Strength KempLN Building & Construction 21 06-17-2006 11:06 AM
