Magic Chef Furnace - Appliances - DIY Chatroom Home Improvement Forum
Old 11-08-2011, 10:03 PM   #1
magic chef furnace
step by step instructions to turn on forced air furnace
fastnfree is offline   Reply With Quote
Old 11-08-2011, 10:08 PM   #2
magic chef furnace
provide step by step instructions to turn on air forced furnace
Old 11-08-2011, 10:35 PM   #3
Rewards Points: 508
Not much to it.
Make sure breakers in electric panel are on.
Make sure emergency shutoff switch at furnace is on.
Set thermostat to heat position.
Set desired temp above room temp.
If furnace is ok it will start sequence to get flame.
Inducer fan on.
Pressure switch closes (edit).
Glow plug or pilot lights.
Burners ignite.
Blower starts within a couple of minutes.
All assumes clean filters, motors lubed.
diyorpay is offline   Reply With Quote
Old 11-08-2011, 10:45 PM   #4
I'm Your Huckleberry
Rewards Points: 2,270
New install, wiring troubles?
Btw, pressure switches do no turn on, they close.
Doc Holliday is offline   Reply With Quote
Magic Chef Oven fault code F-5 bigalp Appliances 3 08-25-2011 07:56 AM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
