Low Cold Water Pressure - Appliances - DIY Chatroom Home Improvement Forum
Old 10-11-2012, 11:38 AM   #1
Low cold water pressure
Why Do I Have Low Cold Water Pressure On My Kenmore Electronic 90 Series Washer
MANUEL644 is offline   Reply With Quote
Old 10-11-2012, 12:22 PM   #2
Rewards Points: 52
Turn off the valve on the cold water supply line, remove the hose to the washer, inspect the screen in the end of the hose, and clean as necessary. If that does not resolve the issue, place a bucket under the spigot, and open the valve momentarily, to see if the flow to that point is sufficient.
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Low cold water pressure in shower peezee Plumbing 2 05-07-2011 05:30 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 09:05 AM
