-   -   Loud Jen-aire oven (http://www.diychatroom.com/f47/loud-jen-aire-oven-54053/)
loudoven 09-29-2009 11:28 AM
Loud Jen-aire oven
i have a jen-aire dual fuel oven range (model SVD48600P). When the temperature of the oven gets above 220 degrees a very loud fan turns on (it sounds like the fan that goes on when you are doing a self clean or broiling). the maytag guy said it was normal but there is no way that loud of a noise is normal. Plus, it hasn't always done this and i know someone else with the exact same model that doesn't make such a loud noise. Any suggestions on what the problem may be?
thanks
Viper16 09-29-2009 12:25 PM
was the maytag guy at your home listening to the fan or did you explain over technical hotline?
loudoven 09-29-2009 01:47 PM
he was at my home. he said he thought that is came on at too low of a temp. he, as well as the maytag technical helpline insisted that a fan is on those ranges, which I realize, but the noise is too loud. you can hear it from the other room. my father has the exact same oven...makes no noise.
Ron6519 09-30-2009 09:18 AM
You seem to have the answer. Now you need to convince Maytag.
Ron
loudoven 09-30-2009 05:00 PM
do you think it is the blower fan. I was interested in ust doing this myself just don't know what the difficulty level is.
ibzbro 10-04-2009 03:41 PM
it sounds like its probably a squirrel cage cooling motor, you might be away with just doing a small adjustment of the fan or maybe something got inside it... ex wires, insulation, paper manual ect... look for the easy stuff before you go replacing parts but better yet i would make another service call and request a different technician to come out. persistance and success go hand and hand....:thumbsup:
ibzbro 10-04-2009 03:43 PM
also make sure its not you covection fan blade hitting the cover. is this sound happing on convection and or normal bake?
