Loud Daily Rumble In Crawlspace. - Appliances - DIY Chatroom Home Improvement Forum
Old 02-07-2011, 10:08 AM   #1
Loud daily rumble in crawlspace.
3 times a day at 8.30am, 11.30am and 1.30pm, there is a loud rumble in my crawlspace and my house shakes for a second. It happens everyday at these same times regardless of any appliances I am running at the time. It sounds like a large appliance being dragged across a floor. Any ideas?
mcartier is offline   Reply With Quote
Old 02-07-2011, 10:59 AM   #2
DIY staff
Rewards Points: 7,174
Have you gone into your crawl space during those times?
fungku (02-11-2011)
Old 02-10-2011, 11:28 AM   #3
RDS
Rewards Points: 150
Blasting in your neighborhood?
When I first moved in my house shook every day at 10:30 a.m. Baffling. Turned out a few streets over, a construction project was ongoing and they had permits to blast once per day, and they always did it at the same time.
Edited to add: Although 8:30 a.m. seems a little early for blasting.
RDS is offline   Reply With Quote
Old 02-10-2011, 11:44 AM   #4
fabrk8r
fabrk8r's Avatar
My only thought would be a sump pump that is excessively noisy. The problem with that theory is that they work on a float switch, not a timer, and it's unlikely that the pump would come on at exactly the same times every day.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 02-10-2011, 11:47 AM   #5
Experienced
Jackofall1's Avatar
Have you had a ride on that train yet?
Do you live above a mine?
That rat that lives in your crawl space is eating all the deer in the neighborhood.
Mark
Old 02-10-2011, 01:38 PM   #6
ghost...
UFoPilot is offline   Reply With Quote
Old 02-11-2011, 12:57 AM   #7
Contractor - Renovations
fungku's Avatar
is there anything on a timer in your home? furnace maybe?
How long have you lived there and has it always done that?
Have you gone down and looked? or are you too scared?
fungku is offline   Reply With Quote
Old 02-11-2011, 06:43 AM   #8
DIY staff
Original poster has vanished-----I hope the noise in the basement was not a hibernating bear with a snoring problem.
Old 02-11-2011, 10:21 AM   #9
Rewards Points: 598
gma2rjc is offline   Reply With Quote
getting the most out of a heated crawlspace Gerry Fossum HVAC 2 06-08-2011 07:42 PM
conditioned crawlspace fan albertpinto HVAC 4 12-27-2010 04:46 AM
Crawlspace Moisture - Serious Problem PaoloM General DIY Discussions 11 12-15-2009 01:35 PM
Insulating an unheated crawlspace indignatz Building & Construction 7 10-28-2009 06:29 PM
crawlspace exposed to outside and damp djbauda Building & Construction 5 07-30-2007 07:49 AM
