Lost And Confused - Appliances - DIY Chatroom Home Improvement Forum
Old 03-31-2013, 11:18 PM   #1
lost and confused
I just bought a 40 gal hot water heater and new 10/2 wire and new 40 amp breaker i wired it up and have nothing what could be the problem
jtmc27 is offline   Reply With Quote
Old 03-31-2013, 11:33 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 776
Did you turn on the breaker?
Is the thermostat turned on?
Have you measured the voltage at the water heater?
ddawg16 is online now   Reply With Quote
Old 04-01-2013, 01:14 AM   #3
Rewards Points: 192
Did you wire this to a two pole breaker and put the black under the terminal of one of the breakers and the white under the other terminal on the other breaker?
I am assuming you wired it with the white to the nuetral bus bar.
Make sure you put the bare ground on the grounding bar.
bcgfdc3 is offline   Reply With Quote
Old 04-01-2013, 08:26 AM   #4
Rewards Points: 12,794
"A 40 Amp. breaker" scares me, was it a double or single pole breaker?
With a single pole your only going to get 110 volts. Need a double pole breaker.
Old 04-01-2013, 08:46 AM   #5
MarginallyQualified
Rewards Points: 2,464
Originally Posted by jtmc27 View Post
I just bought a 40 gal hot water heater and...
it could be that you didn't ALSO buy a decent meter.
Use a meter to determine that you have 240V coming out of your double pole breaker (also use one at 30A)... then determine that you have 240V at the WH end of the wire.
From there it's about following the instructions that came with the heater.
(and using a few wirenuts)
Old 04-01-2013, 12:03 PM   #6
Sounds like you're going to have to upgrade your current system to accommodate for the 40 amp breaker. Sounds like a bit much for a water heater, but then again I haven't bought a new one in quite a few years.
Metro is offline   Reply With Quote
Old 04-01-2013, 07:54 PM   #7
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
Just a swag.
Wired wrong
Turned power on before filling with water and burnt the elements.
jbfan is online now   Reply With Quote
Old 04-01-2013, 11:11 PM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 776
Well....seeing how the OP has not been back since he posted his question.....I suspect he figured it out...or is just another 1 post wonder.
Old 04-02-2013, 03:50 AM   #9
paper hanger and painter
chrisn's Avatar
Rewards Points: 120
That, or he blew the freekin house up
Confused by my 3way switch Toller Electrical 3 01-06-2013 06:12 PM
Roofing\venting proposals = Confused homeowner 2Kwiet Roofing/Siding 18 11-12-2012 03:10 PM
PICTURES - confused over double light switch wiring - help! brightlight Electrical 14 08-04-2012 11:53 AM
Leveling a ceiling in an unfinished basement - I'm TOTALLY lost and confused... mensrea Carpentry 10 03-22-2011 07:14 AM
Lost power help homeowner4 Electrical 10 04-02-2010 06:07 PM
