-   -   lost and confused (http://www.diychatroom.com/f47/lost-confused-176005/)
jtmc27 03-31-2013 10:18 PM
lost and confused
I just bought a 40 gal hot water heater and new 10/2 wire and new 40 amp breaker i wired it up and have nothing what could be the problem
ddawg16 03-31-2013 10:33 PM
Did you turn on the breaker?
Is the thermostat turned on?
Have you measured the voltage at the water heater?
bcgfdc3 04-01-2013 12:14 AM
Did you wire this to a two pole breaker and put the black under the terminal of one of the breakers and the white under the other terminal on the other breaker?
I am assuming you wired it with the white to the nuetral bus bar.
Make sure you put the bare ground on the grounding bar.
joecaption 04-01-2013 07:26 AM
"A 40 Amp. breaker" scares me, was it a double or single pole breaker?
With a single pole your only going to get 110 volts. Need a double pole breaker.
TarheelTerp 04-01-2013 07:46 AM
Originally Posted by jtmc27 (Post 1150008)
I just bought a 40 gal hot water heater and...
it could be that you didn't ALSO buy a decent meter.
Use a meter to determine that you have 240V coming out of your double pole breaker (also use one at 30A)... then determine that you have 240V at the WH end of the wire.
From there it's about following the instructions that came with the heater.
(and using a few wirenuts)
Metro 04-01-2013 11:03 AM
Sounds like you're going to have to upgrade your current system to accommodate for the 40 amp breaker. Sounds like a bit much for a water heater, but then again I haven't bought a new one in quite a few years.
jbfan 04-01-2013 06:54 PM
Just a swag.
Wired wrong
Turned power on before filling with water and burnt the elements.
ddawg16 04-01-2013 10:11 PM
Well....seeing how the OP has not been back since he posted his question.....I suspect he figured it out...or is just another 1 post wonder.
chrisn 04-02-2013 02:50 AM
That, or he blew the freekin house up:eek:
