Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 10-31-2011, 10:21 AM   #1
Little cold water to washing machine
I had the water turned off for a day and now the cold water just drips into the washing machine. I took the end off that was connected to the machine because someone told me there was a filter that caught debris when the water came back on, however I didn't see a filter.
ladydispatcher is offline   Reply With Quote
Old 10-31-2011, 10:49 AM   #2
Shut off the power to the machine at the circuit breaker, unplug the machine, turn off the valves at the wall, slide the macchine out from te wall far enough, unthread the hose from the machine, put the hose in a bucket, and turn the valve back on. If you get a good supply of water, the problem is in the machine. If not, disconnect the hose from the valve on the wall, and see if you get a good supply of water from the valve. If so, the problem is in the hose, and if not, the problem is in the supply line.
Old 10-31-2011, 01:00 PM   #3
Sometimes the filter is at the end of the hose attached to the wall faucet.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Hot Water in Cold Water Lines ??? Superbuuck Plumbing 14 08-29-2011 01:21 PM
Replacing Washing Machine Water Shutoff Valve aimforthenail Plumbing 8 08-05-2011 11:18 AM
water line for new washing machine jensu2 Plumbing 1 07-18-2010 10:51 AM
New Kenmore washing machine, automatic water level question DIY DUDE Appliances 2 04-16-2010 08:52 AM
Hot Water Turning Cold - Could it be the washer/dryer? kissiffer4 Plumbing 3 01-28-2010 05:47 PM
