Line From Fridge Compressor Frosting Over - Appliances - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-19-2011, 02:52 AM   #16
the most likely cause of the suction line frosting all the way back to the compressor is an over charge of refrigerant.
corrinla is offline   Reply With Quote
Old 09-20-2011, 10:51 PM   #17
The cause of a suction line frosting is that the saturated temperature of the refrigerant is below 32 f degrees. The evaporator coil could have an ice build-up, from not defrosting properly. Or the unit is low on charge. Frosting is a sign that the evaporator pressure is low enough to flash the liquid off, but not enough air flow to let the refrigerant absorb the heat in the freezer.
If the system was overcharged enough to make the suction line start freezing, the compressor would of been dead by now.
Master of Cold is offline   Reply With Quote
Old 09-20-2011, 11:28 PM   #18
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,584
wrong again
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
DIY Comedy--PVC for main water line? Daulton Plumbing 8 03-23-2011 10:03 AM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 03:56 PM
Can a roof vent identify where my main sewer line exits the house? YerDugliness Plumbing 8 01-26-2010 05:13 PM
electric line and gas line couch potatoe Electrical 17 09-30-2008 11:43 PM
