LG Washer Wm0642hw Won't Spin - Appliances - DIY Chatroom Home Improvement Forum
Old 01-12-2014, 07:07 AM   #1
LG washer wm0642hw won't spin
Bearing were bad in my unit, so I replaced bearings, seals, stator wiring harness and position sensor. The rotor and stator were very dirty with rust. I cleaned them with water and a light brushing and let it dry for at least 4 days. Got the whole unit back together and ran a speed load empty. She seemed a little jerky in the wash and rinse cycle ans never really got into a spin. I ran a second load with towels and now she won't spin in a wash cycle. Did I ruin my stator and if so should the rotor as well or is that good. I got no error codes, she just does not spin. Also, you can hand spin with no problem.
ricanmd is offline   Reply With Quote
Old 01-12-2014, 12:20 PM   #2
Rewards Points: 232
It's possible, or it may still be wet, unplug it and give it some more time to dry. Place stator/rotor in a better location to dry out or gently use a hair dryer to dry all the water out. Going forward, there is a special solvent and procedure for cleaning the stator windings/rotor. Oily dirt and rust is not necessarily a problem.
Depending on model/type, some come together as a complete set. If either one is bad it will cause the problem you're having. Before investing another 200 dollars on it, give it a little more time to dry out. Just remember water got in between all those windings, it should be totally dry before it will work correctly. Just a thought. Stay tuned, others will be along shortly with more advice.
click here for quick link to repairclinic
jmon is offline   Reply With Quote
Old 01-16-2014, 06:13 PM   #3
Well I took it apart and found that the rotor had been stripped. I replaced the rotor today and not it tries to spin with a load of towels but no go. So I took out some towels and it does spin. Then it ended with a LE code. It has been making this noise since I started it the first time. See video. I relaced the hall sensor when I rebuilt it. SO the stator is all that is left.
Frigidaire Affinity front loading washer 2006 model-won't spin final spin? imola ghost Appliances 9 10-23-2015 05:23 AM
Kenmore washer spin speeds? Ultrarunner2017 Appliances 0 12-09-2013 03:22 PM
GE Washer will not perform final spin joeycranston Appliances 6 01-19-2010 12:06 AM
GE washer No spin when loaded SPSNEXPERT Appliances 4 06-29-2009 01:39 AM
Maytag washer spin cycle problems. billmac Appliances 1 07-16-2008 05:03 PM
