LG Washer ? - Appliances - DIY Chatroom Home Improvement Forum
Old 05-06-2010, 06:08 PM   #1
LG washer ?
Well we messed up big time and need a little help. Have a LG front loading washer. The Mrs. cleaned the soap dispenser trays last night and must not have got them in right. Now the trays are wedged against the top so the soap door will not open. Is there an easy fix or do I need to disassemble the whole upper part of the washer to get the top off and set the trays right?
Old 05-06-2010, 07:35 PM   #2
Rewards Points: 286
That sounds like a situation where pictures might help. One would think if it went in it should be able to follow the tracks back out. Can you get a feel for how much pull it will tolerate before breaking? And how much to replace the tray if it does break? Next I would weigh the cost of replacing the tray if it does come out in pieces against the difficulty and potential damage to taking the washer apart.
Jim F is offline   Reply With Quote
Old 05-06-2010, 08:21 PM   #3
few points
LG sells replacement parts
the washer breaks down and comes apart.
if you do break anything, break the soap dish as it's cheap to replace, other parts around it are more costly
i learned this checking on parts for my dryer. believe it or not credit cards can slip past the lint trap and wedge in the blower. sounds like a bike wheel with cards. LG has a good distributor chain and after i tore my dryer open i learned i didn't even need anything
racebum is offline   Reply With Quote
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
Moving Washer and Dryer upstairs from basement pennypoopie General DIY Discussions 3 08-23-2009 05:29 PM
relocating washer drain idodishez Plumbing 7 04-21-2009 08:36 PM
Washer Drain line extention Born In America Appliances 1 02-28-2009 03:55 PM
220V Washer 3-pronged to 220V dryer-outlet Primergy Electrical 19 03-27-2008 10:40 PM
