LG Tromm WM2277HW - Appliances - DIY Chatroom Home Improvement Forum
Old 10-26-2011, 06:45 PM   #1
LG Tromm WM2277HW
I am getting a code OE. The washer has clothes in it and the door will not open. Will not drain. I went to drain out and emptied water and cleaned out filter then the door opened. There was a lot of water that drained out. When I started the washer again it did the same thing. I think the water pump has gone out. Does it sound like it has by the description?
ckprince is offline   Reply With Quote
Old 10-26-2011, 07:10 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
oe means the machine did not successfully drain all the water out, as you already have figured out. Did you pull the filter out and clean it or just clean it? Did you check inside the pump to see if it was plugged or jammed? May be bad pump but I would suspect it is plugged or jammed.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
