LG Refrigerator (LRBN20510WW) Is Leaking From The Bottom - Appliances - DIY Chatroom Home Improvement Forum
Old 05-06-2008, 08:19 PM   #1
Angry
LG Refrigerator (LRBN20510WW) is leaking from the bottom
I have this problem with my bottom mount frezzer, it keeps leaking water. I have tried to adjust the door where it stays up and closed, but it did not help. I have tried cleaning the seal and not sure yet if that is going to help or not. Is this a common thing on this model and if so is there a way to fix it or should I just go out and buy a new one. Any help would be great.
Jgro461 is offline   Reply With Quote
Old 05-07-2008, 12:08 AM   #2
jeff1's Avatar
Hi,
Where?
Inside? On the floor?
If on the floor, any ice inside the freezer?
jeff.
Appliance Repair Aid
www.applianceaid.com
JRAppliance
www.jrappliance.ca
jeff1 is offline   Reply With Quote
Old 09-25-2008, 04:49 AM   #3
Maybe you can call LG service center and ask them what the best thing to do is.
jmmv08 is offline   Reply With Quote
Old 09-25-2008, 05:03 AM   #4
Rewards Points: 60
Is that a self defrosting refrigerator? Or maybe the condenser has a problem.
Best is contact your manufacturer :-)
Last edited by AtlanticWBConst.; 09-25-2008 at 06:46 AM. Reason: SITE RULES VIOLATION: Advertising Links Removed From Signature
home decorations is offline   Reply With Quote
Old 10-28-2008, 08:51 PM   #5
is there ice on the bottom of the freezer. If so the drain clogged and every time it defrosts the water is running out the door instead of to the drain pan
sv9779 is offline   Reply With Quote
Ice and Water Shiled over or under Drip Edge? Leaking Roof sbt3 Roofing/Siding 8 05-03-2008 12:00 AM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 09:53 PM
leaking pipes tina cosio Plumbing 2 10-26-2007 09:39 PM
leaking bathtub mikeynholly Plumbing 1 02-11-2007 02:50 PM
