Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 01-29-2013, 08:14 PM   #1
LG dryer won't turn when start button pushed
Hello,
My LG TROMM front load dryer won't start when start button is pushed. However, if I take the top off and manually spin drum it turns and continues normally. Any ideas what causes this?
Thanks,
tdsilk
tdsilk is offline   Reply With Quote
Old 01-29-2013, 08:52 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
bad motor winding
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 01-30-2013, 01:08 PM   #3
Originally Posted by hardwareman View Post
bad motor winding
Thank you. Does this require a new motor? If so, is there a recommended place to purchase? Lastly, can someone point to the steps to replace the motor?
Regards
Old 01-30-2013, 04:56 PM   #4
If it the case then yes, it will need to be replaced. The motor can be bought at a local appliance store that has a service dept. They can also, maybe, give you some pointers on changing it out. Not real hard to do, just need to unhook everything that is attached to it and is holding it in.
danpik is offline   Reply With Quote
Old 01-30-2013, 06:53 PM   #5
#1 HAWKEYE FAN
i would rate changing an LG dryer motor at about a difficulty 6. You have to remove the top (easy) remove the front & remove the bulkhead (not so easy).
GE Gas Dryer only runs when 'Start Knob' is held. Ximerian Appliances 16 08-17-2012 07:49 AM
Under counter washer / dryer installation wstt Plumbing 0 04-10-2012 12:00 PM
Dryer Venting Question cbzdel HVAC 4 05-18-2011 03:16 PM
Maytag dryer drum won't start when hot dmdonnay Appliances 2 01-10-2011 10:00 PM
Pilot light button on furnace won't turn whydonchathen HVAC 5 10-06-2008 12:03 AM
