-   -   LG dryer won't turn when start button pushed (http://www.diychatroom.com/f47/lg-dryer-wont-turn-when-start-button-pushed-170512/)
tdsilk 01-29-2013 07:14 PM
Hello,
My LG TROMM front load dryer won't start when start button is pushed. However, if I take the top off and manually spin drum it turns and continues normally. Any ideas what causes this?
Thanks,
tdsilk
hardwareman 01-29-2013 07:52 PM
bad motor winding
tdsilk 01-30-2013 12:08 PM
Originally Posted by hardwareman (Post 1105216)
bad motor winding
Thank you. Does this require a new motor? If so, is there a recommended place to purchase? Lastly, can someone point to the steps to replace the motor?
Regards
danpik 01-30-2013 03:56 PM
If it the case then yes, it will need to be replaced. The motor can be bought at a local appliance store that has a service dept. They can also, maybe, give you some pointers on changing it out. Not real hard to do, just need to unhook everything that is attached to it and is holding it in.
hardwareman 01-30-2013 05:53 PM
i would rate changing an LG dryer motor at about a difficulty 6. You have to remove the top (easy) remove the front & remove the bulkhead (not so easy).
