LG Dryer DLG2526 won't stay lit
Gas dryer will not stay lit.
Recently we had a float stick on our sump pump while we were away for christmas vacation and we had just under 11" of water fill up our unfinished basement.
I replaced the dryer igniter today and now it lights but will not stay lit. I've taken apart the gas valve assembly to find 1/2 tsp of water in there and this still didn't fix the problem. There are two electrical valves for the gas, at least one them appears to be working. With a section removed from this assembly, I can see the one plunger move. Not sure how the other valve works for this gas assembly.
Questions being, am I in the right place or could a thermistor or thermostat we causing the problem?
Your help in rectifying the issue would greatly be appreciated. Thanks!
