LG DISHWASHER ID This Part Please? - Appliances - DIY Chatroom Home Improvement Forum
Old 04-24-2014, 06:48 PM   #1
Rewards Points: 18
Question
LG DISHWASHER ID this part please?
Have a LG dishwasher MODEL LDF6810ST/01. We had a water line leak( that was repaired)and everything had to be removed from the cabinets, dry wall, to tiles and the DW. upon placing the dishwasher back in its place and connecting the lines, there was a drip coming from this part. see attachment. the water is coming from the blue portion of part. is this the water inlet valve? if not, what is it? Thank you for any help...
lawmom is offline   Reply With Quote
Old 04-24-2014, 08:28 PM   #2
Rewards Points: 232
I believe you are correct, that is your water inlet valve. Could be defective, if defective they cannot be repaired that I know of and must be replaced. First, being how you had the dw disconnected, check your hose clamp to the inlet valve, make sure it's secure/seated properly and not leaking to rule that out.
If no luck there, click on the link below picture, view the part replacement and part testing video's when you get there, maybe it will help you out a little better. Others will be along with more advice/suggestions. Thanks.
water inlet valve
jmon is offline   Reply With Quote
Old 04-24-2014, 09:55 PM   #3
Rewards Points: 18
Thank you jmon. I appreciate your taking the time to answer.
The Following User Says Thank You to lawmom For This Useful Post:
jmon (04-25-2014)
Old 04-25-2014, 03:01 AM   #4
Rewards Points: 744
water inlet valve
It looks like jmon nailed it. Nothing to add.
Seattle2k is offline   Reply With Quote
The Following User Says Thank You to Seattle2k For This Useful Post:
jmon (04-25-2014)
Old 04-25-2014, 10:43 AM   #5
Rewards Points: 232
Your welcome. Let us know how everything worked out for you. Thanks.
drain hose for new dishwasher -doesn't match old one? denemante Plumbing 1 11-01-2011 01:57 PM
Dishwasher wiring tcarter Electrical 5 10-04-2011 10:47 AM
Dishwasher powder instead of salt - Doh! Bottletops General DIY Discussions 0 03-03-2010 12:06 PM
Thinking about installing a dishwasher kossuth Appliances 1 09-23-2009 11:05 AM
