Leveling Washer - Appliances - DIY Chatroom Home Improvement Forum
Old 01-29-2013, 05:32 PM   #1
Rewards Points: 225
leveling washer
Trying to level washer. The feet in the back of the washer are not self leveling. Washer is close to being level but will not level completely. Any suggestions on how to adjust the levelers? Thanks.
gt1935 is offline   Reply With Quote
Old 01-29-2013, 07:49 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
if they are not self leveling then they screw in or out to level
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 01-29-2013, 08:57 PM   #3
Rewards Points: 27
"Close" to being level is usually all that is necessary.
kreemoweet is offline   Reply With Quote
Old 02-02-2013, 09:11 AM   #4
Rewards Points: 516
You likely will have to tip washer to see rear feet to determine if you need a screwdriver, visegrip pliers or wrenches to loosen adjustable screw system. If they are fixed position, then front feet were designed to go up or down enough to give full ranges to level (except probably in an uphill or downhill place where 99 out of a 100 people would not place an appliance). Sometimes (and recently) some brands were recalled because no adjustment was possible to eliminate vibrations. Check for any recalls.
diyorpay is offline   Reply With Quote
Old 02-02-2013, 09:17 AM   #5
Civil Engineer
Rewards Points: 4,944
If the levelers are broken, you can adjust using wooden or metal shims.
Daniel Holzman is online now   Reply With Quote
Old 02-04-2013, 04:57 AM   #6
selenajones
leveling washer
Will you please tell us what brand and model of washer you are using and what is the age of your washer? Some washer have independently adjustable feet and some have not. If you have first type of washer then you have to do some steps.
1. Place the level on the front of the washer's top cover. Place it parallel to the washer's face panel. Observe the reading on the level.
2. Place the level on the edge of the washer's top cover. Place it perpendicular to the washer's face panel. Observe the reading on the level.
3. Move the washer away from the wall a few inches if it needs to be leveled. Tip the washer back and slip the block under the front to hold the front feet off the floor. Loosen the lock nuts with the wrench, then turn the feet in or out as dictated by the level readings you saw in Steps 1 and 2.
4. Tip the washer back, then slip the block out from under the front. Set the washer's front feet on the floor. Tip the washer forward, then slip the block under the back to hold the rear feet off the floor. Loosen the lock nuts, then turn the feet in or out as dictated by the level readings you made in Steps 1 and 2.
5. Tip the washer forward, then slip the block out from under the back. Set the washer's back feet on the floor.
6. Repeat Steps 1 and 2 to check for levelness. Repeat Steps 3 through 5 until the washer is level and all four feet touch the floor.
7. Tighten the lock nuts against the washer cabinet on all four feet once the washer is level.
8. Move the washer back to its intended position. Recheck levelness to be certain the washer is level and that all four feet touch the floor.
9. If your washer parts like washer feet or washer level lock nut is broken then you have to replace the foot or have to adjust with wood or any solid material.
pandorasoem1 is offline   Reply With Quote
Under counter washer / dryer installation wstt Plumbing 0 04-10-2012 11:00 AM
bolt that holds the tank to the toilet bowl is leaking andrewjs18 Plumbing 13 04-06-2012 10:43 AM
Washer & Dryer Holiday Fun BRIANisMEisWE Appliances 8 12-24-2011 02:41 AM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
Moving Washer and Dryer upstairs from basement pennypoopie General DIY Discussions 3 08-23-2009 05:29 PM
