Leveling The Refrigerator VS: Door Closing - Appliances - DIY Chatroom Home Improvement Forum
Old 12-08-2010, 01:24 PM   #1
Leveling the refrigerator VS: Door closing
The Whirlpool Side x Side fridge we got six yrs ago works great but for one prob: The right side door (fridge side) doesn't auto-close. The magnetic seal works fine but you have to close the door to get it there. Freezer door works great; it will self-close if it's anywhere NEAR shut.
The manual says to level the fridge to cure this. In fact, level is the ONLY thing the book lists as a problem when this condition occurs. Using my 2-foot bubble level, it was about a half-bubble off level when I started. This, measuring side-to-side, across front of the fridge. When I bring it to level, the door still acts the same way. There are no adjustments for leveling the rears.
Right now I'm out a couple hundred bux worth of food since the door was open about 1/2 inch all night, and the unit was warm inside this AM.
The doors are both hinged on the outside, opening from the center. Left door operates properly. Right side door does not .... and my common sense tells me that side needs to go UP in order to allow gravity to swing the door.
But lifting that right side up had no effect. FWIW, there is nothing heavy in the door, and it swings fine with no obstruction inside or out.
HELP!
SanDiegoPaul is offline   Reply With Quote
Old 12-08-2010, 01:34 PM   #2
the Musigician
DangerMouse's Avatar
Can you post a pic of the hinges? It may need a readjustment.
DM
Old 12-08-2010, 01:56 PM   #3
DM
Cool, thanks. Upper & lower hinges:
Leveling the refrigerator VS: Door closing-p1010064.jpg   Leveling the refrigerator VS: Door closing-p1010065.jpg
Old 12-08-2010, 02:06 PM   #4
the Musigician
Remove the plastic cover on the top hinge.
Shoot another pic... kinda from above/sideways angle.
DM
Old 12-08-2010, 02:58 PM   #5
DM
OK here ya go ....
Leveling the refrigerator VS: Door closing-p1010066.jpg   Leveling the refrigerator VS: Door closing-p1010067.jpg
Old 12-08-2010, 03:02 PM   #6
What is not apparently obvious in these two shots is something that I see when standing over the fridge: That door that's in question appears very close at the outside, by the hinges and the other side is not as close. I.E. the seam on the door seal is completely closed (crushed shut) at the hinge side of the door just like it is on the freezer door that works correctly. But toward the other side of the refrigerator door the gap is wider. That door actually sticks out a bit more in the center of the unit, than the freezer door does.
Old 12-08-2010, 03:02 PM   #7
the Musigician
hmmmm... mine's slotted to allow left to right adjustment.
Does the door sit flush and plumb to the top and sides when closed?
DM
Old 12-08-2010, 03:03 PM   #8
the Musigician
cross post... never mind, you just answered me.
DM
Old 12-08-2010, 03:12 PM   #9
the Musigician
Does the bottom have slots? Can you take another pic? lol
DM
Old 12-08-2010, 03:43 PM   #10
DM
OK Mouse man, hope this helps!
Leveling the refrigerator VS: Door closing-p1010069.jpg   Leveling the refrigerator VS: Door closing-p1010070.jpg   Leveling the refrigerator VS: Door closing-p1010071.jpg
Old 12-08-2010, 03:45 PM   #11
DM
Flush, no but plumb? Reasonably depending on how level I make the front adjustments.
Old 12-08-2010, 05:49 PM   #12
the Musigician
Is the distance the same, on the hinge side, (between fridge body and door) at the top and bottom?
DM
Old 12-08-2010, 08:08 PM   #13
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
those little black plastic things on the bottom side of the door on the hinge, those are little cams that if are not worn out will make your door self close. I suspect yours are worn and need to be replaced
hardwareman is offline   Reply With Quote
Old 12-10-2010, 03:07 AM   #14
How do you replace 'em?
Old 12-10-2010, 10:43 AM   #15
#1 HAWKEYE FAN
pull the door by removing the screws in the top hinge, the closure is held on by a screw
Tags
door , leveling , whirlpool refrigerator
Leveling concrete slab acerunner Building & Construction 13 10-06-2010 07:25 AM
Drywall or studs first before self leveling cement sandoy1121 Flooring 0 07-26-2010 06:50 PM
self leveling cement questions gramps416 Flooring 0 07-05-2010 09:36 PM
floor leveling compound geraldS Flooring 4 03-01-2009 08:20 AM
Portland based self leveling underlayment under travertine floors Keith Carlson Ceramic Flooring 7 01-25-2009 03:58 PM
