Lenox Central Air Condition - Appliances - DIY Chatroom Home Improvement Forum
Old 07-12-2011, 05:48 PM   #1
Lenox Central air condition comes on right after you turn on and air comes out for about 60 seconds then it shuts off. What do you think it could be?
sgsimmons is offline   Reply With Quote
Old 07-13-2011, 06:47 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Blower motor overheating, thermostat is bad, control board is bad..
Is this happening in all three: cooling mode, fan on mode and when in heating mode?
Doc Holliday is offline   Reply With Quote
Closed off room where central return is located markorious HVAC 1 02-17-2011 01:47 AM
Central Vac problem strongbow Electrical 4 10-23-2010 08:49 PM
central air vs window units sharonjo General DIY Discussions 6 07-22-2009 08:37 PM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 11:49 AM
Installing Central Air using existing heat ducts lvlacic HVAC 2 06-25-2005 12:47 AM
