Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 06-23-2010, 03:16 PM   #1
mg3
Lennox G41 uf leaking
My unit is @ 6 years old and has just started to drip water onto the blower fan. I just went into the basement to find a LOT of water. It has been a week since I was down there.
I cleaned out the float assembly and line initially before I found exactly where the water is coming from.
Any ideas that a reasonably handy man could tackle?
Thanks,
PS it's 95 degrees out so any advice would be appreciated.
mg3 is offline   Reply With Quote
Old 06-23-2010, 06:17 PM   #2
Check the filter and the bottom side of the coil. If the condensate line wasn't plugged up then it's probably freezing and you're seeing the run off from when it melts. Lack of air flow across the coil or low on refrigerant are what cause freezing.
lennox elite furnace leaking water outboardhuy HVAC 10 09-24-2011 11:43 AM
HELP: Lennox C33-36C-2F leaking water hamproof HVAC 33 06-26-2010 03:48 PM
Wiring Tradeline L6006C Aquastat to Lennox CBWMV Hydronic Air Handler VIPSpecialNeeds HVAC 5 03-15-2010 07:37 PM
Leaking air from lennox handler/furnace unclesam HVAC 1 02-22-2010 01:08 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 09:53 PM
