Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 09-07-2007, 06:46 PM   #1
leaking fridge door
have2001 whirlpool ref/freezer with thru door ice/water dispenser. Have water leak inside door (water Line) - have replacement line and fittings - need to know how to remove outer trim from dispenser so I can pull it forward and replace the line - any ideas - Thanks in advance.
paxxxx is offline   Reply With Quote
Old 01-11-2008, 02:45 PM   #2
leaking fridge door
To remove the trim on the dispenser look along the bottom edge and you should find two slots.
Use a flat blade screwdriver to pry out and release the clips.
Once the bottom edge is released slide the trim up and off.
This will give you access to the screws to disassemble the dispenser.
girltech is offline   Reply With Quote
French Doors from Homedepot or Lowes??? johnnytuinals General Discussion 47 01-10-2009 11:00 PM
Freezer leaking into Fridge? jc2709 Appliances 1 05-23-2007 10:55 AM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 09:43 AM
Fridge Door Handles Leenders Remodeling 1 04-19-2006 11:59 PM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 03:09 PM
