-   -   leaking fridge door (http://www.diychatroom.com/f47/leaking-fridge-door-11359/)
paxxxx 09-07-2007 06:46 PM
leaking fridge door
have2001 whirlpool ref/freezer with thru door ice/water dispenser. Have water leak inside door (water Line) - have replacement line and fittings - need to know how to remove outer trim from dispenser so I can pull it forward and replace the line - any ideas - Thanks in advance.
girltech 01-11-2008 02:45 PM
To remove the trim on the dispenser look along the bottom edge and you should find two slots.
Use a flat blade screwdriver to pry out and release the clips.
Once the bottom edge is released slide the trim up and off.
This will give you access to the screws to disassemble the dispenser.
