Laundry Room & Bathrooms Share A Vent - Appliances - DIY Chatroom Home Improvement Forum
Old 06-25-2013, 03:36 PM   #1
Laundry room & Bathrooms Share a vent
I recently bought a new condo and bought an electric washer & dryer set with it.
In our unit, we have a closet that houses an electric water heater and has space for a stackable washer and dryer unit. The closet also has a ceiling vent, but i found out it connects with the bathroom and exhausts through a central ventilation shaft in the roof.
What are my options for venting the dryer? I am looking at a Lint Trap filter like this: http://www.amazon.com/Indoor-Lint-Tr...oor+dryer+vent
Will the vent on the ceiling of the closet be safe to vent out warm humid air?
justinangil is offline   Reply With Quote
Old 06-25-2013, 05:50 PM   #2
Rewards Points: 13,450
Dryers need to be on there own line and vented all the way out the roof or the wall.
Not even sure how those things can still be sold legally.
That would still vent hot moist air.
Old 06-25-2013, 06:48 PM   #3
Rewards Points: 20
If the closet was designed to house a washer and dryer, it should have a separate duct connection for the dryer. Does it have hot and cold water supplies and a drain?
Dan
djlandkpl is offline   Reply With Quote
Old 06-25-2013, 09:28 PM   #4
Yeah the closet has water supply and drain
Here are some pictures of the supply and said vent
I was told that the vents are attached,
Old 06-25-2013, 09:39 PM   #5
Rewards Points: 20
Maybe it's behind the access panel above the water heater. Is there a management company that you can ask?
Dan
Old 06-26-2013, 08:50 AM   #6
I pried that access panel open and it led to another part of the vent. I'll try to get a picture of what's behind the panel.
Mgmt was the one that told me that the system is connected.
This is my first time living in a home with a vent system. Any input is much appreciated!
Old 06-26-2013, 09:52 AM   #7
Rewards Points: 20
The pic will help.
Thought about it some more. I bet the connection is inside that panel. It should be a 4 inch round duct and it may have a cap on it.
I have a relative that lives in a high rise condo. The dryer and bath exhausts are tied together in the same duct work. The duct exhausts out the side of the building. When she uses the dryer, she turns on a switch next to the dryer which powers a remote blower. It's the same blower for the baths. One way you can tell if your set up is the same is to lower the grates for your bath exhausts. If there's no fan behind it then you have a remote blower set up.
Dan
Old 06-26-2013, 09:39 PM   #8
Opened up the access panel.
Seems to be another access to the vent.
Sorry for the image size.
Any idea what the access vent is for?
Old 06-27-2013, 05:30 AM   #9
Rewards Points: 20
It looks like a clean out. Anyway to look at one of your neighbor's set up?
Dan
Old 06-27-2013, 11:26 AM   #10
Neighbors told me they use ventless dryers too. Looks like I will have to return my current W&D and get the ventless stackables. Thank for your input!
Old 06-27-2013, 11:50 AM   #11
Rewards Points: 20
You learn something new everyday. I didn't know about ventless dryers. Guess you save space as the washer and dryer are 1 unit.
Dan
Old 07-03-2013, 09:28 AM   #12
Rewards Points: 274
Thanks for sharing.
alexjoe is offline   Reply With Quote
Old 07-03-2013, 09:37 AM   #13
Rewards Points: 274
Thanks for sharing.
Need a foundation in my laundry room sweetfarm Building & Construction 14 09-06-2012 09:49 PM
Laundry Room Divider - Help! Soxckersfc2002 Carpentry 1 05-07-2011 01:50 PM
Water Tight Laundry Room (prevent water from spilling over into other rooms) asummit Remodeling 6 03-29-2011 05:17 AM
Laundry Room Addition Completed hyunelan2 Project Showcase 6 02-27-2011 10:42 PM
Replacing a laundry room roof. Tomcat1066 Building & Construction 5 11-11-2006 03:08 PM
