Large Gap Beween Stove And Wall - Appliances - DIY Chatroom Home Improvement Forum
Old 03-15-2016, 02:29 PM   #1
NMB
Rewards Points: 2
Large gap beween stove and wall
Just moved into a condo. It has a slide-in electric range. There is a 2-3" gap between the wall and range. I realize I should redo the counter-top so it wraps around the range, but that's not in the budget just yet. Is there a temporary solution? It's going to drive me crazy if anything spills back there while cooking. Plus it just looks funny.
NMB is offline   Reply With Quote
Old 03-15-2016, 02:35 PM   #2
WhatRnsdownhill's Avatar
Rewards Points: 2,220
Re: Large gap beween stove and wall
try pushing the stove back against the wall..is there anything blocking you from doing this?
WhatRnsdownhill is offline   Reply With Quote
Old 03-15-2016, 10:57 PM   #3
Rewards Points: 112
Maybe this: http://www.walmart.com/ip/Kleen-Seam...Color/37115713
ChuckF. is online now   Reply With Quote
Old 03-16-2016, 08:29 AM   #4
Rewards Points: 1,426
In my house the hard gas line comes through the cabinet and prevents the oven from being pushed back. Is there something behind your unit that prevents pushing it?
mikegp is offline   Reply With Quote
Old 03-16-2016, 08:30 AM   #5
Originally Posted by ChuckF. View Post
That looks like it's for the side of the stove. Between the appliance and the counter.
Old 03-16-2016, 09:07 AM   #6
dd57chevy's Avatar
Rewards Points: 242
Is the gap on the back or on the side of the range ?
dd57chevy is offline   Reply With Quote
Old 03-16-2016, 10:27 AM   #7
Hmm, now that I reread it, maybe the range is against a wall on one side and there's a gap. I thought he meant behind. If that's the case, get a small piece of counter top and build something skinny that it can sit on. Finish the front with something that looks like your cabinets.
Existing Brick Wall for Wood Burning Stove sonnaps Building & Construction 13 09-24-2015 02:03 PM
Load Bearing Wall? Master Brian Building & Construction 3 06-05-2015 11:32 PM
Wall Prep for Wood Burning Stove Install Kory Beam Building & Construction 10 04-02-2015 01:24 PM
triple wall stove pipe TRZ Insulation 1 09-25-2011 11:02 AM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
