Kohler Whirlpool Wont Turn On - Appliances - DIY Chatroom Home Improvement Forum
Old 10-04-2009, 11:54 AM   #1
Kohler Whirlpool wont turn on
My 8 year old indoor Kohler whirlpool stopped turning on this morning. The power to the 20A dedicate GFCI outlet is fine. The whirlpool has a 2 speed switch for high and low. When the switch is pushed nothing happens.
I tried reseating the switch cable at the motor. Based on my research the problem seems to be one of the following:
1. Bad switch ($83 with cable)
2. Bad circuit board ($404)
3. Bad motor ($?)
I would like to check the swtich. It has 4 conductors with a telephone jack connector on the end. Does anyone know the pinout for these switches?
To replace the circuit board I will need to pull the model. Do I need to replace the gaskets if I decide to pull the motor?
Thanks for any advice that you can offer
swieder is offline   Reply With Quote
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
Kohler Whirlpool not turning off tnt2006 Electrical 6 08-29-2014 09:41 PM
adding inline heater to Kohler K1148 whirlpool tub rpbdiy Plumbing 1 07-30-2009 06:51 PM
