Kitchenaide Gas Stove Works Fine, Oven Doesnt! - Appliances - DIY Chatroom Home Improvement Forum
Old 04-01-2011, 07:18 AM   #1
Kitchenaide Gas Stove works fine, Oven doesnt!
Please help...Kitchenaide KGST307HBs1
Everything works fine...stove burners, broiler, electronic keypad.
The oven stopped working, no smell of gas. I tried flicking the main house fuse, no luck. tried the gas line, but the stoves are working so I dont think it is that either.
I think it is something with the ignitor or the burner itself, but cannot confirm. I tried playing around with the piece that allows to increase/decrease flame size for the oven burner located underneath the oven (but it was pointless because there is just not flame at all...cold to the touch). Tried to use a match, still no luck.
Which part do I need to buy, and can i install or do I need a pro?
THANK YOU!!!
gr8tefloyd is offline   Reply With Quote
Old 04-01-2011, 02:36 PM   #2
Rewards Points: 760
You aren't going to light the oven with a match. Your oven has an glow bar igniter. It has probably burnt out, it does happen.
Can you change it yourself, yes. Should you, probably not. Don't take offense but "playing" with the air shutters wasn't a good idea and the oven burner will likely need to be adjusted for the proper flame.
Any parts store should be able to get you a new igniter for about $70. It shouldn't take a "pro" that long to install and you'll also get a warranty with it and the piece of mind of knowing the oven has been adjusted correctly.
AandPDan is offline   Reply With Quote
The Following User Says Thank You to AandPDan For This Useful Post:
fabrk8r (04-01-2011)
Old 04-01-2011, 03:23 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
does the ignitor turn red when you turn on the oven, if not the ignitor is probably bad. I hate it when when homeowners try to fix their own appliances before they call me, 10 times out of 10 they cause more problems by trying to "fix" it themselves. Costs me more time and them more money.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Ge oven BUDDYSHADOW Appliances 6 11-23-2010 01:16 PM
Wiring Stove Top and Built in Oven whoog Electrical 2 08-17-2010 01:10 PM
GAs Oven works broiler does not .... fburke Appliances 1 09-23-2008 09:16 PM
Gas oven does not work; pilot light on, stovetop works fine kathleentsy Appliances 1 05-22-2007 05:05 PM
Three electricans said it was impossible! Tom Electrical 35 04-29-2006 05:06 PM
